Thank you Greg, Gary, Carlos and Bruce!
speedgraflex wrote: ↑Thu Sep 24, 2026 1:01 pm
Kari!
Beautiful. Two notes if you want them:
1. Make a plastic jig to keep the supports aligned.
2. I would drill out a hole in the plastic supports first before inserting the rod. This would countersink the tip and provide stability as well as alignment.
Thank you Bruce, you have read my mind! I made a very simple jig, but I think I need to look for another rod, other material that is easier to work with. This leaves some tension, does not really look.
And as a matter of fact, though not very visible in the photo above, I drilled holes in the plastic supports for the rod. It definitely helps.
I’ve also been thinking (the main reason I started with this part instead of the skis) about making the supports with the rods in a new jig first (to get them aligned and identical), and only then attaching them to the skis. This way, it would be much easier to paint them before gluing them to the skis.
Here my (disclaimer: ”my current”) jig:
But lets see!
