Went back to HL and bought the hobby tool organizer. Took me about 1/2, 45 minutes to assemble. It is 10 1/2 inches wide, 10 inches deep on sides, 4 1/4 inches at highest end (back) and 2 inches high up front. It appears to made of particleboard/thick cardboard material. Similar you find as spacer boards in boxes of furniture you have to assemble.
I must warn you, it is a biatch to put together. Parts are not labeled but I strutting guide tells what part is what by shape.
Two parts did not fit as instructed. I test fitted both parts letter G and letter I because they are slightly the same. The middle shelf notches and bottom shelf notches will not line up with either G and letter I parts.
Middle shelf notches were clipped off to fit properly. This is the bottom view underneath. It's suppose to sit in the notch openings. Nope...
Bottom shelf will not fit in notch hole. Notches clipped off as well.
Poor manufacturing of parts but it is a nice organizer. It's a wonder I didn't break any of the parts.
Holes can fit brushes, eye droppers, pencils, hobby knife
