Henschel 126
Re: Henschel 126
VanceCrozier wrote:I'll just leave these here for further conversation. The daughter looked at it, closely, for a good 5 minutes. Proclaimed "well that sucks", and went to bed. :scream:
Yeah - that be daughters for you - but hey, look on the bright side - at least you got a comment :grin:
Yeah I can see a bit of a fit :quotes: issue :quotes: with those struts...
VanceCrozier
Re: Henschel 126
Post by VanceCrozier »
The main struts/supports seem to set the wing in a good spot, but, the inner fuselage-to-wing supports are too long; wing to main strut braces far too short. Brass rod to the rescue I suppose. :headbang:
I am a riddle, wrapped in a mystery, inside an enigma, smothered in Canadian bacon.
Re: Henschel 126
this is why this hobby is so much :quotes: F U N :quotes:
VanceCrozier
Re: Henschel 126
lol, it's more fun when stuff (mostly) fits on its own though!!! :bag:
I dunno, I went back and just looked at it, moved things around, twists & bends, I just don't see anything that I could've done to cause it to be so far off. It's almost like there is supposed to be some anhedral built into the wings, that isn't there?
Re: Henschel 126
It sounds remarkably like the Revell SE5a I built a while ago - I'm sure the strusts were for a different kit... :bored:
VanceCrozier
Re: Henschel 126
If I didn't snip them off the sprue myself, I'd be wondering the same thing!
Manny1943
Re: Henschel 126
Post by Manny1943 »
The two large main struts slot into the fuselage nice & solid after I sanded the corners a touch. Maybe a touch low on the trailing edge of the wing, but not bad. The other struts... well, I think the technical term is "caddywhompus". Not even close. Thinking I now need to rebuild those "N" shapes with... stretched sprue (inconsistent but easily attached) or brass rod.
Yeah, that DOES suck...but the idea of replacing them outright is a good one and easily done since they are straight rods...DO IT and stop CRYING!!! :ballbat:
VanceCrozier
Re: Henschel 126
Yep, that main strut woulda been a massive pain to replace, but in this scale, I think I can get away with individual lengths of brass rod.
Manny1943
Re: Henschel 126
Post by Manny1943 »
VanceCrozier wrote:Yep, that main strut woulda been a massive pain to replace, but in this scale, I think I can get away with individual lengths of brass rod.
DO IT!!! And then ship that last batch o smileys!!! :DI:
VanceCrozier
Re: Henschel 126
Jawohl, mein herr!
