Hasegawa 1/72 Mig-27 D (Flogger)
Hi All,
I just started yet another wip, so I thought I'd post it up, I'm building this...
Hasegawa's Mig-27D. I'm rather in to these old Hasegawa kits at the moment and this one is certainly vintage. The detail is a bit basic but the fit is not bad, and although it has (gasp) raised panels lines they are nicely done - it's certainly very buildable.
This is what's in the box, not a great deal as you can see...
And this shows the highly detailed and accurate cockpit...
So off we go - this'll be a OOB build, but fun anyway!
Cheers
Re: Hasegawa 1/72 Mig-27 D (Flogger)
So here's where I am now - assembled the rear fuselage and started laying down basic paint.
There're a couple of bad sink marks along the rear of the fuse, so I've added a bit of tamiya basic putty to them and the seams.
I've not used Tamiya basic putty before so we'll see how it goes.
Cheers!
Actually although I was going for an OOB buildI don't think I can live with the total lack of detail in the cockpit so I might add in this...
Yes it's for a BAE Hawk but I find these Hawk PE sets really useful for sorting out the cockpits in old jet kits - the instruments look ok for 'classic' jets and because the side panels are not shaped they're easier to fit - AND you can sort out two kits with one PE set! (Unless it's a two seater)
We're talking 'appearance' of detail rather than accuracy!
So that's my tip of the day if you enjoy playing with these older kits!
Cheers!
Here you go Mr. Templeton.
I love everything Russian that is able to fly. Tough choice of kit!
BsYamato
Post by BsYamato »
I like this plane :) i builded two academy lots of years ago. one destroyed the other alive.
Followip :)
This is just a great plane and therefore automatically a great build!
Smart idea with the PE sets! :-)
I passed on this kit when I saw it at a show cause it had raised panel lines. I hate them with a passion!! :ggun:
Can't wait to see more of the build! :popcorn:
A tip on using Tamiya putty: when the putty is still wet you can wipe the excess of with a qtip soaked in nail polish remover (with acetone). That saves you from a lot of sanding. Or you could thin the putty in nail polish remover and use a small brush to apply it sparingly.
Thanks Gents!
Borg - Thanks for the tip with the NP Remover - I'll try that next time I use it!
BsYamato wrote:I like this plane :) i builded two academy lots of years ago. one destroyed the other alive.
Followip :)
So that's the same kit but with recessed panel lines correct?
there you go Medic - that's your answer! No raised panels! :giggles:
