Photoflash compartment cut out of the fuselage and scratched together, I may open the left side as well after finding out they used the left side banks first after I opened the right side for a "post" sortie setup, and since the doors don't exist on the Tamiya C I would have to scribe them anyways. Everything is dry fitted, the cartridges are the 123's commonly used in this era. I still need to trim the size of them but you get the idea......
The Cutting Edge Seamless intakes I have were full of wrong or missing panel lines as well as pin holes galore ,,, so I either had to use the kit pieces filling and sanding 1/8 inch ledges in it or.... take a dremel and grind away at what was garbage to make it useful ,,,, so I ground the resin paper thin and mated the kit pieces too it.
All I have to do now is prime the insides and sand all the raised panels down and scribe in one missing panel line, as always thanks for looking!
