1:48 Petljakow Pe-2 Peschka
Re: 1:48 Petljakow Pe-2 Peschka
I can't believe how quickly this went together! Great work CL - it's looking fantastic - that's a great looking model of a really interesting aircraft.
- Cherrylock
thanks, portman only little steps day by day,no big problems, it is not so much I have done on one day
- Cherrylock
Nice diorama, CL.
Ahhh, nice.
Got the AAA here too, its really a nice kit, but a bit hard to find. It even came with PE parts as far as I can remember.
Dio looks good too.
Dio looks good too.
Great work !
Did you use the decals provided in the box ? Zvezda is (was ?) notorious for the poor quality of the decals but I read somewhere that they were improved with their Pe-2
- Cherrylock
thanks all.
wasabi this are the decals from the box and the hole Pe-2 is OOB, they are fine, little bit Mr.softer and I have no problems. They are flat and not us thin as Eduard but ok.
tigrazor: some times you fine this GAZ, I have the refueler on stash, not so easy to build, lot of parts with no fixation pins and there are some PE parts, most for the engine,the front pomper is plastic but the connection to the frame is a PE angle..
The Eduard ground crew is nice molded, better than the ICM, but the ICM work and the Eduard talk and have a flip chart in there hands..both neaded
That's a superb dio CL - thanks for sharing it.
