I happened to read through the model review section in the IPMAS website and I came across this product called Liqiud Gravity by Deluxe Materials. Although I have never heard of this product, but it states it can be found in the UK. Sounds like a great alternative to finding other means for weight on tail sitter aircraft. I clicked on the youtube link on the link provided and saw they use another product called Hot Rocket. to seal in the Liquid Gravity.
http://web.ipmsusa3.org/content/liquid-gravity
For those of you across the great pond, have you used it? What are your thoughts on it?
Liquid Gravity
Liquid Gravity
Re: Liquid Gravity
Never used it personally, but heard positive answers. Alexander Glass from "Uschi van der Rosten" has something similar, he calls it "Three Green":
http://www.uschivdr.com/products-in-det ... se-weight/
Re: Liquid Gravity
I still have plenty of birdshot left.... No need for anything else.
Re: Liquid Gravity
I thought about it for my Heinkel salamander bird. Probably steel wire and two holes for the ground and the wheel will help too. Its even cheaper.
- Thomas_M
- Admin
Re: Liquid Gravity
I have this Liquid Gravity and used it to get some (unnecessary) weight into the leading edge fuel tanks of my Horten build. The lead is of a very fine grain that easily flows into the smallest gaps or openings, as the sides of a kit cockpit or the open space of a front landing gear bay.
A nice-to-have product. Having poured in one could fix it with a coat of Magic Sculp, super glue, or even wood glue.
Re: Liquid Gravity
I use it for all my models that requires weight in the nose - very easy to use - just put a layer of CA down and pour it on - let it set and then bash off the excess (into a box so you can re-use it) - excellent product.
- Tojo72
Re: Liquid Gravity
Sounds like good stuff,price would be a consideration.
- Thomas_M
- Admin
Re: Liquid Gravity
Found a picture using this stuff to fill a leading edge fuel tank:
One square of the cutting mat equals 1 centimetre.
Re: Liquid Gravity
Is there a warning of do not mix with "Liquid Courage"?
