Opel Blitz, DAK style
AgentG
Senior Member
Post by AgentG »
This is my take on the venerable Opel Blitz kit from Italeri.
Not very complex, but still holds it's own after all these years. Biggest issue I had was this one was molded in red, black and tan plastic.
Given my prediliction for armor modelling you could guess where this was going.
Krylon Gray Primer makes a good base.
Wired the engine a little bit then realized the hood was molded shut. Not any more.
Four different colors later I had my mix for RAL 8000, a desert yellow brown used early on in North Africa
.Image
Stay tuned.
G
AgentG
Senior Member
Re: Opel Blitz, DAK style
Post by AgentG »
As promised, an update.
A nice relaxing paint session yielded these results.
The base coat.
I used another mix of Tamiya colors to come up with RAL 7008, Graugrun .
A stencil set and Tamiya Flat White was used for the Africa Korps palm symbol.
More to come.
G
Looks very good, but where are the wings?
Very nice! Excellent camouflage pattern and I commend you on the remarkable stenciling.
Most of the older Italeri 1/35 armor/softskin kits are pretty sharp! They still hold up well to this day. Much better than most of the Tamiya kits of the same vintage. Nice work so far G! :shoutout:
That is super looking build - I really like your painting on that camo!
Thomas_M
Post by Thomas_M »
Looking good!!!
For you mentioned the different colours of the plastic: is this the 1/35 or the 1/24 scale kit? I once did the larger one, and this one had the multicoloured plastic. A pretty well fitting great kit!
AgentG
Senior Member
Post by AgentG »
Thank you all.
This is the 1/24th scale kit. Thought I'd try my hand at weathering something larger for a change :giggles: .
Here's where I'm at as of this afternoon.
Weathering is done with mostly oils at this point.
I got some really neat stowage items from Steve at Value Gear. They are from his 1/16th and 1/20th scale set.
So by picking and choosing appropriate size items I can go for a real "Indiana Jones" style diorama.
G
Wow, I did not know that they did a 1/24 scale Blitz. Nice!
Me neither! Man, that is big! Great scores from Value Gear! He's the Best!
