54 Chevy Sedan Delivery-COMPLETED 09/16
Re: 54 Chevy Sedan Delivery-A Little Humor-03/20
LOL!!! I think I can either find or replicate one! If I do this it's going to have to be beyond the gray primer stage though. lol
And a motorized shopping cart next to it. There's one using them every time to go to Walmart. Drives me crazy for they act like they own the damn aisles.Duke Maddog wrote:That's gonna rock! You gotta add the handicapped placard too you know...
LOL!!! I've seen a few mean old ladies in those things!!
I was hoping to be more along than what I am here but this part took alot of work. First off I added a wiring harness that I still have to do some work on regarding a couple of circuit breakouts from the main harness. I took a piece of telephone wire and stripped the end off of it and used coil winding wire from a GM fuel pump relay to wind around the phone wire to replicate the plastic black conduit that you see on alot of more modern engines. Then I put a terminal end on the alternator cable with a nut glued onto that. After that I started on the throttle linkage by building the bracket and pivot lever (which was four pieces when you count the two PE retaining bolt heads that I glued onto it going into the intake manifold) and got that glued in.
I'm going to put a hold on the fine detail for the time being and build up the headers, paint them and glue those into place so I don't have to handle the engine very much when installing the rest of the throttle linkage and fuel delivery pieces.
Progress pics:
I'll be using braided fuel line like this:
and anodized fittings like this (I've already got these on order BTW ) to replicate the fuel delivery system:
Progress pics:
Re: 54 Chevy Sedan Delivery-Engine Progress-03/23
My eyes will hurt if I worked with something that tiny. Looking forward to seeing more engine detailing.
Thanks guys! It hurts my eyes too Tom! Lol
I was going to delete this picture from my camera but decided at the last minute to keep it because it's a clearer shot than I thought it was. At first glance it looks like the same stuff but clearly visible in this pic is the work that I completed this morning in regards to the throttle pivot shaft bracket assy on the rear carburetor and the throttle linkage at the intake. You can't really see the gap between the bracket and the manifold with the naked eye but you sure as hell can see it with the macro setting! lol.
In any case....todays update (it took me two and a half hours to get this done this morning!)
A little closer. That bracket consists of four pieces: 1) the standoff bracket itself 2&3) the retaining nuts for the bracket to carburetor and for the bracket to the shaft pivot mount at the other end and 4) the shaft pivot mount assy. Believe me.........that's two and a half hours worth of work!!!
Re: 54 Chevy Sedan Delivery-Throttle Linkage Progress-03/24
My head hurts. LOL! Awesome work!
Thanks Tom! My head hurt too from all that time with an optivisor on. lol
