Well, there!
The canpoy was attached with liquid cement, a good, airtight joint. You can see on the pic how well you can see the cockpit detail.
Now it was time to turn to the exterior details and stuff, starting with the rocket boosters.
The exhaust lips were thinned to scale and we're good to go!
BTW, the Japanese RATOGs weren't very reliable. They had plenty of trouble fine-tuning them. One can only imagine what would have happened if the placement was slightly off-axis or if there was a lag in ignition time...
Next the FOD covers: simple styrene discs with copper wire grab handles. I glued some supports on the inside of the intake and exhaust so that when the covers are put in place at the end of the build they don't fall into the fuse with no way of retrieving them...
The trolley was detailed somewhat with rubber cushions, a lunette ring and weld seams (made from stretched sprue softened with liquid cement and shaped with a sharp blade) where there were unsightly gaps.
This being a prototype the gun ports were removed by filling them.
For those who like this kind of stuff, here's an excerpt from the Konpeki no Kantai animation showing how the Katsuodori could have been put to use. The a/c depicted looks more like an Okha but the concept is pretty much the same.
https://youtu.be/X5vIGnk3XJ8
