Meng 1/35 French Main Battle Tank AMX-30B
Re: Meng 1/35 French Main Battle Tank AMX-30B
I found the image on the Tanks Encyclopedia page- and holding the mouse over the image this caption pops up- "Turretless chassis in repair, Bosnia"...but it doesn't say what variant it is....you might definitely be right....I'll look through the two books I have up through the B2...but the rear end of this one certainly seems to match what I see on the model....but there's not much to go by is there?
I know the site you're talking about. A fun one indeed...Jeeves wrote:I found the image on the Tanks Encyclopedia page- and holding the mouse over the image this caption pops up- "Turretless chassis in repair, Bosnia"...but it doesn't say what variant it is....you might definitely be right....I'll look through the two books I have up through the B2...but the rear end of this one certainly seems to match what I see on the model....but there's not much to go by is there?
Finished the initial painting of the NATO scheme...going to fade it a bit and then add some select few decals...and then take my time on weathering
Looks mighty nice.
- Thomas_M
- Admin
Now, that is what I call some progress! Seems you are on the finishing line here!
Thanks everyone- used a mix of putty and tape for masking...seemed to go alright I guess
Thank you!
Nearing the middle phase of weathering...so far did some oil streaking and some powders...
Having some track issues- meaning mainly that the indies keep coming apart in various places...not a fan so much...but I figure I should probably finish everything else first and only fix things once...
Looking real good! Almost at the finish line!
