As I have said, I have been doing little bits of progress here and and there and taking photos along the way, but holding off on getting them on here until it was kinda worthwhile with something to see. With the completion of the cockpit tub parts in Step 1, step 2 is several other nose area parts. so far I painted, assembled and attached the nose wheel well. The roof of the well had three ejector pin marks on the outer face for some reason while the side walls had them on the back side... not the wisest engineering
so first it was a base coat of white, then a few metallics and black in there for detail work, a wash to make all the raised detail stand out, them some more colored pencil work for the color codings on the hydraulic lines (as busy as the parts look, the real place is way busier), and finally a clear coat to seal it all in.
Then I glued the sidewalls in place
and glued the well into the forward fuselage lower part
I also assembled the chin sensor fairing (after adding some lead shot for some extra up front weight- just in case)
Now my next week or so is full, so no more real progress for perhaps another 10 days or more...
