Then this morning the final stages of construction began. I glued on the idler and sprocket wheels and placed the tracks on as well. As you can see they were a bit a springy and loose fitting
then I added some brass wire pins into holed that I had pre drilled to tamp down the upper track runs
then I added the side laminate armor plates. Once those had set I began to add the final detail parts as well
exhaust pipe
right side grab handle/step
left side grab handle/step
smoke grenade launchers
pioneer tool shovel and spare track shoe mounting bolts
pioeer tool pick mattock head and handle
pioneer tool axe, tankers bar, and maching gun tripod.. I also added a bit of strip styrene to teh shovel mount to make a proper bracket instead of having it free floating on the upper side
and a couple of overall views
I have puttied up where the side laminate armor joins the rear plate and am waiting for that to dry to sand it later and then I can begin final painting...
