The fuselage halves are next.
A closer view of the fuselage surface prior to the riveting work.
The rivet lines are drawn onto the surface of the fuselage using a pencil. I don't get too exact here and simply eyeball the rivet line position based on the scale drawing. My primary guide for drawing the lines is a flexible plastic ruler. For areas with significant curvature, such as around the engine, I use Tamiya white plastic tape.
It's important for me to scribe each line carefully and under magnification so that the riveting tool stays on the correct line. If I do this right, I do not need a straight edge to guide the riveter and this simplifies the process somewhat.
After the rivets have been applied, I give the entire surface a light rub with very fine sandpaper to knock down the ridges around the rivet holes. Rivet close to panel lines may distort the plastic into the recessed lines so I will gently run my scribing tool along those panel lines to restore their edges.
This view was supposed to be used in comparison with the unscribed picture but due to the lighting, you can hardly see the rivets. I guess it's a good perspective in that it shows the subtlety of the rivets. I want them to add visual interest to the surface but not overpower it.
There is at least one row of rivets that I blew as I lost control of the riveter around the engine. I just remembered it now as I was typing this update. I should have filled them in with Mr Surfacer putty yesterday so that I could re-rivet today but I'll have start on that putty work later today.
