Yes...........and no.Stikpusher wrote:Is this going to be in a NMF?
1/48 B-25J Mitchell
Re: 1/48 B-25J Mitchell
Ok... I think I know where you're going with this one...
Time for some engine work!
The Mitchell is looking good in her black base. The PE wiring harness for the engine is a good addition. I like to give the harness a few coats of brushed-on paint to remove that "flat" look.
What color would you use?jkim wrote:The Mitchell is looking good in her black base. The PE wiring harness for the engine is a good addition. I like to give the harness a few coats of brushed-on paint to remove that "flat" look.
Tamiya Red Brown XF-64 is what I normally use for engine ignition wiring.Medicman71 wrote:What color would you use?jkim wrote:The Mitchell is looking good in her black base. The PE wiring harness for the engine is a good addition. I like to give the harness a few coats of brushed-on paint to remove that "flat" look.
Medicman71 wrote:Yes...........and no.Stikpusher wrote:Is this going to be in a NMF?
Stikpusher wrote:Ok... I think I know where you're going with this one...
The nose guns snap off yet?
I hope not...
Nope not yet. One waist gun might be close though.
