BsYamato's rotors
Re: BsYamato's rotors
You are making some good progress!
BsYamato
Post by BsYamato »
Thanks Borg :)
Updates about windows, glued with CA glue from the inner and sanded with file and sanding paper , now the windows have the same thickness of fuselage. More fine sanding to improve clearness i will do before paint
Last night works:
Washing and closed fuselage. Doors engraved by me
Painted as usual the instruments
Added seat belts and seats
Final touch with aluminium foil upper IP screen
Test with cockpit inserted
Just for fun actual hobby boss helos in the stash :drum:
At the next!
BsYamato
Post by BsYamato »
I lost the scratch upper consolle so i did another and painted (it's just a plasticard square painrted :) )
And placed
Glued upper canopy and cockpit block
Horizontal surfaces aligned
At the next!
That trick with the windows sounds risky but I think it will turn out fine. Some unsolicited advice: 4-way nail files can polish and buff it back to a shine. The last bit can be done with Tamiya compound or even whitening toothpaste.
BsYamato
Post by BsYamato »
Thanks Borg, i'll get the nails files soon, also whitening paste already in the house :) just waiting some step before to polish the windows .
Ps the clear parts was protected by future (yes I get a little bottle) clear varnish
BsYamato
Post by BsYamato »
Updates
Glued canopy and detailed the web intake on the rotor basement
More pieces on
Added details to the main rotor, not yet finished
Tail rotor detailed and replaced the kit cap in the tail light position
Gear on ,handles and hinges to the doors
Drilled and glued side exhausts
Testfitting
At the next :)
CallSignOWL
Post by CallSignOWL »
fantastic work as always, BSY! :bow:
Looks all ready for paint now...
Good to follow your progress on this one! Interesting to see how you pick and choose what to detail and why—interesting and inspiring. Good luck with your "at the next!" :shoutout:
Superb build of a rather natty kit BSY - Great work. I'm really impressed with the extra effort you've put into the cockpit and the clear parts.
Return to “Whirlychopters”
