The HobbyBoss Kit
The box was very large and sturdy and that gave a really good impression of how big the actual kit may have been. The boxart was also very good.
Once opening the box, I saw that the kit has a lot of parts, by just looking that the sprues which filled up the entire space of the box. They were all in light grey. The box was divided into two section. The main area with all the major sprues and a small section on the righ/left side that housed smaller spues, rubber vinyl tires, white metal landing gear, and PE sets. A truly multimedia kit!
If you like lots of parts then you would like this kit. however, I found out it was only a first impression. once you start building, you will find out that the kit is very simple and that the large part count is for the cockpit, landing gear and wheel bay, and missiles set.
PE was rather basic but after building this kit, not many were needed
White metal landing gear. Its not a truly 100% white metal landing gear. They are meant to work in conjunction with the plastic pieces so that the overall landing gear is sturdy.
The love and hate of vinyl tires. They are nicely molded and have no serious flaw on their thread. The only caveat in using vinyl tires are that you will need to find a different way to make them look 'weighted'. On thing that was bugging me was the fact that the tires were a tad to wide for the rim (they were not a really tight fit) and thus slightly a bit wobbly when installed.
