I used two part mold putty to take an impression of the head on the remaining part so a new one could be cast in resin,
and hopefully now back on track
Thank you Bruce! Making the replacement part was really "that" easy; the two part putty is kneaded together 50/50 until it is a uniform color, press the head of the good part into it to get an impression, and then let the putty set up. I think it takes a coupe hours to set up, I did it before leaving for work, and when I cam home mixed the resin, again 50/50 put a drop in the impression and then just wait a few minutes for it to kick off.speedgraflex wrote:Scruffy! What a great save for the idler wheel! Two part resin with a mold? You make it look so easy and the result looks amazing! You’re almost done!! What are your base ideas?
Hi Monty, MENG has the Sherman, a Tiger I and a Soviet KV 2 with the tall turret. It was a fun little kit, and not one I would normally consider building, but it was fun and looks cool. If I can find the KV I might build one of those some time too.dmminiatures wrote:WOW. I didnt know MENG had one also. I was in LHS in Singapore last month and saw a hole rack display of Toon tanks, but they were all Hasegawa.
