BsYamato's rotors
Re: BsYamato's rotors
Nice work! Everything is falling together well.
BsYamato
Post by BsYamato »
Time for the messershmitt :)
Some painting on the rotors, removed masks and glossy coat for decals
At the next
Do you apply your gloss coat by hand brush as well?
BsYamato
Post by BsYamato »
yes, this time i used future wax, a friend give me a little bottle to try it :)
meanwhile.. another rotor started few nights ago..
That will turn into this one :)
https://static1.squarespace.com/static/ ... ormat=750w
But probably will open a single thread :)
Nice! The Magnum chopper! I want to build one of those too!
Nice work on the Messerschmidt.
BsYamato
Post by BsYamato »
Thanks Duke :)
As the Magnum P.I. is already at the gloggy coat i put here he too withouth single wip.
I used the Ah-6 italeri notorious kit , in the stash i have another one and two V tail cayuse to build :)
doors locked and windows glued (badly.. as i see after :bag: )
Seats
The cockpit, only added rear ip wires and rear long seat
ready
Added a weight under the floor but forget to take picture :) is not necessary but give a good weight to the too light kit
Glued the fuselage
After a white primer a full yellow on.. and some retouch need
After two windows pull off masked for orange stripes
And in the same session the mixed brown
At the next!
Great work on TC’s chopper so far. You nailed the colors and layout of the striping. :shoutout:
Magnificent work on TC's chopper! I do need to see about doing one of those. I need to find one with the horizontal tail.
Keep them coming Silvio!
What a beautiful paint job! You are so good with color matches! Your work looks spot on.
:shoutout:
Return to “Whirlychopters”
