1/35 SS-23 Spider - Trumpeter
Re: 1/35 SS-23 Spider - Trumpeter
Thomas_M wrote:Finished more (44!) complicated bends on PE parts for the base plate of the missile chamber. Still not decided if I really should struggle to grind the existing detail away to replace it with those 44 parts...
If you have already done the PE bending work, then yes, you should definitely !!
But you could also be selective, perhaps not all the existing details need to be replaced ?
Thomas_M
Post by Thomas_M »
You are right, Kari! Meanwhile, I removed all the raised stuff from the floor and sanded it smooth. I now think about how to align all those PE parts. Tamiya tape should do the trick!
I will no longer complain about all the PE I'm using on the A-10!!
James H
Senior Member
Post by James H »
That PE must've tested your patience.
Superb work!
Thomas_M
Post by Thomas_M »
Thanks, Jim!
Indeed they made me mad here and there. I sat there, asking myself: what the hell are you doing here...
Thomas_M
Post by Thomas_M »
Was busy the last weeks, but managed to make some progress. I removed the moulded-on structure from the bottom of the missile chamber, then filled many(!) pin marks. Sanded, and refilled. Sanded, then sealed with superglue. Not perfect, but ok for me.
I masked the lines where I removed the moulded-on structure, then hit it with a coat of primer. After removing the tamiya tape I could easily see where to attach the PE parts.Attaching those took about half an hour. Don´t ask how much time I spend in preparations...
Thomas_M
Post by Thomas_M »
I also re-started my previous work on the missile. More priming and sanding. For a long time I thought about doing Voyager´s replacement parts for the stabilizing fins. So many individual parts to get aligned and assembled. Simply crazy.
Looking back I am aware that this mostly was no fun, but having succeeded here makes me satisfied. Again I made use of soldering, as those fins really are fragile.
Thomas_M
Post by Thomas_M »
Some more close-up shots of the fins:
I placed the kit´s part of a fin, really a difference!
Not too much time the next months, but I try to keep building this one! Hope you like it!
Thomas_M wrote: I placed the kit´s part of a fin, really a difference!
Oh we do !
The difference is humongous ! Will look even better getting a layer of primer/paint on it!
