1/48 Hasegawa Ju 87B-2 (FINISHED)
lawdog114
Post by lawdog114 »
Hello folks. I thought I would offer my first work in progess thread over here and see how well it goes over :o ................be gentile. Anyways. The Stuka is one of those subjects I've always wanted to do, especially a Battle of Britain version with the "Jericho Trumpet", making it perhaps the first legitimate terror weapon. An awesome Stuka group build over at the FSM forum prompted my enthusiasm about this subject and I found this Hasegawa B-1 on E-bay reasonably cheap.
For this project I procured a Quickboost seat(s). I may still add Exhausts wheels and Quickboost guns....we'll see if its worth it. I procured Superscale sheet (#48-0833) which has two B-1s and a B-2 from the summer and fall of 1940. On a side note, I was curious as to why most Stuka decal sheets represent B-2s from the Russian front? I promptly learned that mostly B-1's participated and B-2 frames didn't arrived until the summer of 1940. By then they were apparently pulled from front line service due to high losses to Spifires and Hurricanes. Perhaps I'l back date the kit. My research said the main difference is the exhausts, props and the radiator flaps under the chin. I also read that "late B-1" Stukas had the exhausts upgraded to the B-2 versions? I am not a Stuka expert so "close enough" is likely going to be good enough for me. I'm really not too worried about a panel line here or vent there.....
I started with the cockpit. I thought the cockpit on the kit was acceptable, certainly from what will be seen anyways. Lately I've been on a trend of using out of the box cockpits that are hard to see, perhaps to save time, dough and energy. For example, in my opinion, resin in an FW 109 or KI-43 would be a waste, however, on a P-47 or P-51, it would be worthwhile to replace it. Besides,careful painting could go along way right? I figured with this turkey, I would just replace the seat and be done with it. Its the main focal point of the cockpit anyways. There is a kit supplied decal for the instrument panel. I decided I would use that too, in lieu of a etch replacement. Here I laid out all of the cockpit pieces before I dove in..
Over at the FSM forum I get alot of positive feedback on how I paint and detail my cockpits. I figured I would offer a step-by-step with pictures here. Its fairly simple and I use a few tricks. Perhaps some of you may get some use out of them.
I started by spraying everything XF-1 Flat Black (no picture). This allows for "shadowing" when the interior color is added and creates depth. My research showed that German cockpits were RLM 02 during the Battle of Britain, then changed to RLM 66 sometime in 1941. I used Gunze Aqueous RLM 02 thinned with X-20 for this. In my opinion, Gunze makes the best RLM colors.
Then its detail painting time, such as black boxes and such. My method involves Tamiya paints dipped into 91% Isoprophyl. I discovered this on accident. The key is to thin it enough to where capillary action will cover the box, coupled with the fast drying of the alcohol, which prevents brush marks. Here I painted the boxes and such XF-69 NATO Black. I usually throw a silver one in there too, just for visual appeal That I use Floquil Bright silver straight from the bottle. Its nice an thin already for brush painting. I used to tape off each box off and spray...UGH! :shock: This way is much more efficient.
Here you can see that the Quickboost seat(s) are very nice. I painted the seatbelts XF-57 Buff and the hardware with Floquil Bright Silver on a fine brush. Sometimes I use a silver Sharpie for the silver.
Here's the cockpit is drybrushed with Floquil Bright Silver (Enamel) detail painted, to include some knobs and switches picked out in red,yellow, and blue. It now gets a coat of Testor's Gloss Coat for a wash barrier (no picture of this...sorry)
Image.
Once dry, perhaps an hour or so, it gets a Detailer wash. To me this is the fun part. I use the brown and black mixed together. I think this stuff is the best thing since sliced bread. Just slop it on...wait a couple of minutes.....then rinse it off with water to your liking.
After the wash has been removed. You can scrub off as much as you want. To my eye, this is about right. I lost the kit gun sight, so I stole one from a Hasegawa Bf 109.
Then the whole thing is sealed with Testor's Dull Coat(Note, I thin my Testor's gloss and dull with Lacquer thinner. They dry very quick.)
....and after a light post shading, which consists of alcohol diluted NATO Black XF-69 and Red Brown XF-64, we are finished. The instrument panel is the kit decal soaked in Micro Sol. After the dull coat, I added a drop of epoxy to simulate the glass lenses.
The nice part of out of the box cockpits......the fuselage usually closes without a fuss :D . Here's a test fit. Like a glove.
Well that's about it. Again, I hope some of these techniques are useful. Thank you and feedback is always welcomed...
Next its on to the airframe. More to come soon.....
Joe
Re: 1/48 Hasegawa Ju-87 B-2 (Work in Progress)
Outstanding! . . . and a great job of explaining! I may learn how to do this, yet....
CallSignOWL
Post by CallSignOWL »
very nice!
do you wash off the wash with running water? Or did I not read that right?
Now thats a promising start. Will follow intently.
Thomas_M
Post by Thomas_M »
Very interesting demonstration! And a very good looking cockpit in the end. Congrats and thanks for sharing!
Same question as Owl: this wash can be rinsed with water?
lawdog114
Post by lawdog114 »
CallSignOWL wrote:very nice!
Thanks everyone. Sorry Owl, I was trying to be creative :oops: It's done just like in the picture with a wet paint brush. The sooner you do it, the less effort it takes to wipe off. You just sort of wash it off with the brush. Sorry for the confusion and thanks for the compliment.
Joe
steve scan
Newbie
Post by steve scan »
Great work and thanks from me too for the demo, very interesting.
Getting an education was a bit like getting a communicable sexual disease. It made you unsuitable for a lot of jobs, then you had the urge to pass it on
lawdog114
Post by lawdog114 »
Thanks Steve. I'm glad some of you will try some of these techniques. I'm finally in for an update. I've been chuggin' away at this turkey. This time of year bench time is scarce...couple hours here...couple hours there. Anyways. First, I didn't like the black hole of a landing light, so I decided to fabricate one. I blanked off the hole with styrene and painted it black. I sliced off a piece of sprue to simulate the lens and then drilled out the center to simulate a bulb in there. I painted the "lens" silver and put 5 minute epoxy on it to make it shiny like glass. I got this idea from someone in the FSM Stuka GB so I shant take credit for it... ;) .
It looks like a light yeah?
Here I test fitted everything. It looks like the Hasegawa wing root gaps will be on coffee break for this build, however, that engine attachment will be hurtful. Here I attached it temporarily with Blue Tac...
I started with the wing to fuselage attachment. Perhaps you all use this trick, or perhaps not. Here is how I deal with my wing roots. It also solves gap issues....works just about everytime. Pull the wings to the root with a strip of masking tape, like a "clamp", THEN Tenax the seam. Don't do it before or the pressure will cause it to ooze out making your life difficult. Leave it to dry.
As I expected, I had a gap where the engine piece attached to the fuselage (the diagonal panel line). Unless the real thing was supposed to look this way, which is certainly possible, this area needed serious work. I filled the gap with styrene rod and sanded it smooth. I them rescribed the lines back in with a sewing needle in a pin vice. What a time consuming PITA this was. Its not perfect but it looks much better than before. For future builds, Does anyone know if this area has a gap on the real thing? Everything else fit great. I built the spats and dryfitted them. These fit great. It was at this time I saw that the "hood scoop" on the upper nose looked deformed on the port side....I panicked. Then I realized it was supposed to look like that :oops:
I pre-shaded the panel lines in XF-1 Flat Black. As I said, the spats are just dryfitted. I'm going to paint them first and add them later. I think it will be easier to fit the wheels in. I still may go with resin wheels. I'll have to see how the kit wheels look built up and painted first. Note the Jericho Trumpet. It was going on there whether my subject had one or not...
The lower surface got RLM 65. This is half XF-23 Light Blue and half XF-2 Flat White. The paint was then lightened with more XF-2 and I streaked the lower surfaces.
I grimed it up a bit with a post shade. Its XF-69 NATO Black and XF-64 Red Brown heavily diluted with 91 % Isoprophl Alcohol. I keep it pre-mixed in the glass jar pictured. I'll add more paint or alcohol as needed. I get all panel lines at the control surfaces, around the engine and aft. It just adds another dimension to the otherwise boring blue. It will probably get more in the way of exhaust streaking later.
The middle B-2 (STG 3) is going to be my likely scheme (subject to change of course, especially if something better comes along). Correct me if I'm wrong, but I didn't think Battle of Britain Stukas had fuselage stripes.
That looks like a hard demarcation line on the fuselage, but maybe a soft one from the wing leading edge forward. Eventhough its a drawing, I figure Superscale did some research. Anyways, the rear was taped of and the front got BlueTac. I then used Gunze Aqueous for the RLM 71 thinned with Tamiya X-20. I think Gunze has really nailed the RLM colors.
I then added XF-57 Buff to the paint and make condensation streaks on the wings. The Buff is a good choice for green or brown colors. Its seems a bit much here, but this will be toned down considerably after all of the other steps. This is where I left off.
I hope to get the splintering done soon.....
Joe
CallSignOWL
fantabulous!
Wow....very nice.
