1/48 Tamiya Tiger I (late)
Re: 1/48 Tamiya Tiger I (late)
This is looking as good or better than most of the 1/35 scale builds I see of this.
Looking forward to a diorama out of you. That outta be a complete showstopper right there.
At the risk of going overboard again, I completely agree with Joe’s assessment of your work here. Perhaps the scale choice led to this creative freedom, but you really nailed this subject and made this kit sing a much larger song with a lot more notes and voices behind it.
kahunaminor
Post by kahunaminor »
Thanks guys,
I appreciate the comments and the sentiment behind them. I am really enjoying the build, it is a breath of fresh air. The Tamiya 1/48 AFV kits are truly gems. I am constrained by the rules of the comp somewhat as far as the use of AM is concerned but I have a couple more Tigers that can be more dressed up, or down.
Here is a stalled dio, the desert workshop. Eduard E-7; Tamiya Kubelwagen and some figures. I may have to finish it with the mojo boost from the Tiger:
Regards,
Kent in Oz
Wow, I am a month late to respond to this incredible post, Kent. Accept my apologies, please. I was... I dunno... I missed the notification somehow. I just wanted to write that this idea looks absolutely incredible. I want to ask if there is a build log on the Bf109 E7 here or online because wow! Wow! Wow! That is something quite wonderful to see.
Is there a particular size that you find is best for a base? I am wondering if the base has to be square or if it is acceptable to go with a rectangular swath of all the action... but I don't know if there is a particular way of thinking about this.
kahunaminor
speedgraflex wrote:Wow, I am a month late to respond to this incredible post, Kent. Accept my apologies, please. I was... I dunno... I missed the notification somehow. I just wanted to write that this idea looks absolutely incredible. I want to ask if there is a build log on the Bf109 E7 here or online because wow! Wow! Wow! That is something quite wonderful to see.
Hi Bruce,
Thanks for the comments. It is one of my favourite builds. I normally don’t use a base, in fact this is the first time back in the hobby that I have considered a diorama setting. I have been reading posts and blogs and books on composition, placement and balance of the diorama. I think as long as the subject matter is contained within the boundaries of the base you are okay.
Here is the build log from Aussiemodeller:
http://www.aussiemodeller.com.au/forum/ ... nor+Bf+109
Regards,
Kent
Kent in Oz
Thank you for the link to your build as well as your thoughts, Kent. I started reading the build log and am following closely. I also noted a completed 1/32 build by you amongst your credits. Is this build on the same forum? I’d be curious and grateful. There is quite a lot of great solutions to problems in your projects—I particularly am studying the seam fills in this kit because these ideas will inform what I try. I think I see kinship in your approach to leave as little traces of modeling assemblage as possible. Also it’s fun to see Veggiemite on the workbench as a storage? Cheers!
kahunaminor
speedgraflex wrote:Thank you for the link to your build as well as your thoughts, Kent. I started reading the build log and am following closely. I also noted a completed 1/32 build by you amongst your credits. Is this build on the same forum? I’d be curious and grateful. There is quite a lot of great solutions to problems in your projects—I particularly am studying the seam fills in this kit because these ideas will inform what I try. I think I see kinship in your approach to leave as little traces of modeling assemblage as possible. Also it’s fun to see Veggiemite on the workbench as a storage? Cheers!
Mate thanks,
I have three completed 32 scale builds (2 Bf109’s and a Fw190D). I shall dredge them up and post them appropriately. I think you will see the progression of my burgeoning skill levels as the 190 was about 10 years ago now and the 109’s are about 3-5 years.
One is here: http://www.aussiemodeller.com.au/forum/ ... 109#p39032
Regards,
Kent in Oz
Thank you, Kent. I just finished catching up to your present progress on the diorama elements—fantastic work! There was a lot to absorb, but I particularly found the fidelity to the source colors so strong! Wow!
Some screencaps I took for reference:
:shoutout:
kahunaminor
Kent in Oz
Thsnks so much, Kent!!! You officially made my day! Cheers!!
