Very nice Bruce, very much so indeed!
Re: Hasegawa 1/32 N.A. P-51D "Cripes A' Mighty" IV SN 44-149
So shiny...
Thank you so much for your replies, Kari and Carlos! I am still waiting for my pilots to arrive. I will feel much better once the last large element to the project is properly fitted.
Sensational work Bruce! I hadn't tried BMF before, although when I was working at Prestige Hobbies I did stock up on it. I never used it and when I pulled it out after many years, it had cracked and dried up. Maybe someday I'll get some more and try it before it cracks. Your work here is inspirational; I'm so thrilled to be following this build.
Thank you so much for your reply, Mark. I sincerely appreciate your support throughout the process of building this model. I really am humbled by the qualities of your own work—tackling so many subjects the way you do—and your knowledge when it comes to working in 1/72 always serves to inspire. The work of all the 1/72 modelers here on SPA Modeler is exciting—because you really have to make hard choices about details and forms. Your camouflage painting is an inspiration to me, too—it’s always a bit of a wonderful shock to the senses when the scale is revealed.
Archer sent a mass email featuring their guide as a free PDF. Did you receive their email? My plan is to scribe paneling and punch rivets as needed. One reason I picked up new superglue is to use this as a hardened seam filler, but I wonder if Milliput will work as well. I still am not entirely sure which way to jump. The Hasegawa plastic takes very kindly to Mr. Cement Deluxe so far, but I need to cover molding alignments. There are some delicate rivets touching those seams.
... looks like the radiator door is closed; it must operate to control air flow; I seem to remember reading about how this works at some point; I think I am gonna model it closed based on what I am seeing during these period photos (the restoration Mustangs seem to keep the door open, maybe that helps keep air flow going through the supercharger; my brain is mush right now). Any thoughts?
Radiators are usually minimally open in flight and max open on the ground to reduce overheating when the airflow thru is reduced.
Thanks so much, Carlos. Now I need to modify the door to close properly!
Cockpit views- the figures shipped out tonight. I am prepping the cockpit seat supports.
Actual- for comparison.
Original kit cockpit- for posterity.
