Re: Frog 1/72 Dornier Do 17 Z, 5K + AS8, KG3, October 1941.
I've built that kit - I converted it to a mk.II - it was good fun if I remember correctly.
KennyX wrote:
portman wrote:God you've bloody done it - the nostalgia got to me - I've put a bid in on this one (as it's the kit I built before) :lashed:
https://www.ebay.co.uk/itm/Airfix-DORNI ... fresh=true
I'm blaming you Bruce!
GOOD FOR YOU, STUART! I support this decision 100%.
It should be quite interesting actually - the in-line engines make it different enough from Bruce's build not to steal his thunder, the work he's putting into the engines is superb. I do agree however I think the MG's will need changing - I'll need to read back through his thread to see which ones he used.
Stuart, I am using these...
https://www.eduard.com/store/Eduard/Bra ... html?cur=2
This will save you having to page through to find the intel!
Thanks Bruce!
Notes I redid the top three braces (I told ya I was gettin' better each time—that learning curve), I filed the mis-aligned bottom and top seams as "true" as possible (going to add a smidgen of putty perhaps), temporarily added the resin propeller hub which looks very nice to me! It is almost 1 am. Time to clock out! Let me know what you think.
Echo thoughts.
BsYamato
Post by BsYamato »
better he seems, just follow the airfix instruction figure, bracets are on the same plan
Afternoon i'll put some closer image withouth propeller if can help :)
speedgraflex wrote:Image
Echo thoughts.
Based on the pictures, I think the work you’re doing is definitely zeroing-in on the kind of fidelity you’re shooting for with this project.
BsYamato wrote:Afternoon i'll put some closer image withouth propeller if can help :)
Yes, please!
KennyX wrote:Based on the pictures, I think the work you’re doing is definitely zeroing-in on the kind of fidelity you’re shooting for with this project.
Thanks so much. I was concerned about filing the steps down on the engine cowling as well. I stopped before getting trouble. There are two injector pin marks on the interior of each cowling that I kind of want to remove. I will need to make a round sanding stick and just go for it.
Dremel... :hmm:
