A bigger boat would be nice, Ken. Sincerely. Now to make that happen!
The plastic seats are from the kit. I like 'em. Always have. I will try the PE version out, maybe. Not sure. Maybe at this point, let's consider the seats for positioning purposes.
Really not bad, though. The molding, I mean—it's quite clean. and the raised surfaces are crisp.
Good job, Frog. Sincerely.
I feel as though the beam is too high. I must consult the book. Indeed, I have located the beam in the wrong spot. It is much too high. The beam should be much lower. I will do this tomorrow. This hopefully will go smoothly as I used two drops of CA. I will try De-Bonder first. It is late. I am out of time, but I wanted to keep momentum going and take Part 20 (there are two of these - port / starboard) and at least get the principle piece of photo etch out of the bag and on the plane. As far as I am able to determine, everything "hangs around" these beams.
