FM 1/72 Bf109K-4,9JG 77 White 1, Düsseldorf, Germany, 1945.
Re: FM 1/72 Bf109K-4,9JG 77 White 1, Düsseldorf, Germany, 19
Thank you, Joe!
Er, well, thank the internet—
I believe “The Modeling News,” posted that where my search engine could find it!
Cheers, bud!
My plan is to use MM Enamel Primer.
P.S. I am starting on your poster and badge...
Cheers, bud!
Awesome PE work and color palette sketch too.
Messerschmitt 109 Addict
Great work on that Braille scale PE stuff! It’s so tiny!
superb PE work Bruce!
Thanks, gents. I was able to add a little CA to the corners without the CA leaking through the bottom of the seat. I flipped the chair upside down at first. The assembly is Step 1 minus surgery of the kit part. I was not sure if I was going to be able to make this work so I skipped the surgery part because really if I messed up here then I would have amputated the part of the kit cockpit holding the top of the fuselage together. There is also a chance that painting this will not work out but that is pretty minimal. It’s probably overkill but with CA I always let the CA cure for 24 hours. Eduard provides a lot of details for the cockpit. Many are painted. All the foundational PE pieces are metal finished, which is a nice way to provide a weathering base.
Hey that could work in your favor! You might discover that it turns out really good.
