1/48 Airfix P-51D “Cheesecake Chassie”
wjkunert
Re: 1/48 Airfix P-51D “Cheesecake Chassie”
Post by wjkunert »
Tamiya has a nice P 51D/K kit which I built as a F 6D recon aircraft of the 1st Fighter Squadron, 2nd Air Commando Group, Burma 1945. Note the camera ports on the aft section. I note the markings are the same as your 51-which looks great.
I painted it with Krylon silver metallic Max paint which is a very close match to the Tamiya spray recommended for the aircraft. I've also built ZM's P 51d and both are great kits. I have the ZM P 51D concept notes and Bret Green's book on the Tamiya P 51D. If anybody is interested I'll let them both go for $25 shipped in the US. Both are excellent books. PM if interested.
kahunaminor
Post by kahunaminor »
Thanks Bruce,
The ZM book will provide a good reference ( I have the He 219 book). I am away at the moment but I can also recommend the Tamiya “How to build...” on the Tamiya P-51. It features a VLR Mustang in one of the chapters. I have both the D and the D/K kits in storage so the book is a welcome addition.
Regards,
Kent in Oz
Thanks, Kent!
I know you are on vacation, so—no worries about responding—enjoy your time off. I am grateful for your thread information! Something Stikpusher Carlos wrote about ICM being a Taniya clone resonated (1/48 versions) and I found an ICM kit as well to serve as my 1/48 P-51 entry point. I am aware of the kit issues but still feel I will be able to build another Iwo Mustang (possibly “Hel-Eter”) using this kit. You definitely helped me to make this decision by opening my eyes to the Airfix kit not being the OOB solution to my quest.
Reading this over, I realize I have buried my lead: I now have two kits of 1/48 P-51D Mustangs, and intend to build the ICM first. I may buy a resin cockpit. I may modify the wheel well. However this kit will be the test subject for the Airfix.
kahunaminor
Welcome back,
Rested from holidays, it was time to get back to the bench. I masked the flying surfaces and a couple of upper fuselage panels and sprayed them with AKI Extreme Metal Polished Aluminium. I then masked the anti glare panel with MM Olive Drab enamel:
Next up is the masking for the US insignia and tail serials.
Regards,
Kent in Oz
Kent,
Welcome back from your holiday! You certainly hit the ground running—or in this case, by painting some beautiful new paneling! Your aircraft looks smooth and incredibly realistic! Great job with the natural and the painted metal surfaces!! Did I miss your meaning and are you planning to use S & B insignia masks as well? Regardless, I am excited to have you back and look forward to your next posts!!
:shoutout:
kahunaminor
speedgraflex wrote:Kent,
:shoutout:
Thanks mate,
It is all smoke and mirrors, or Tamiya tape and time! I have some Maketar masks for the US insignia and serials. First time with multi part masks, so we shall see how we go.
Regards,
Kent in Oz
Your work is amazing. I wanted to check that this area highlighted in red is still NMF and the smoke n mirrors masking is covering the NMF...
kahunaminor
Yep still NMF under some liquid mask.
Regards,
Kent in Oz
kahunaminor wrote:Yep still NMF under some liquid mask.
Regards,
Good. Thanks! I was hesitant to ask, very, your build is quite brilliantly executed!
:shoutout:
Great work on the Mustang! NMF is something that I don't have the confidence to do yet but someday!
