F4U-1A Corsair, Tamiya 1/32 3-14 update
Manny1943
Re: F4U-1A Corsair, Tamiya 1/32
Post by Manny1943 »
wing_nut wrote:Thanks guys.
Sad news.... the engine doesn't fit. I think all I'll need to do it take down the tops of the rocker arm covers. Shouldn't even be noticeable.
You might want to rethink that...maybe display the engine next to the plane as a stand-alone and drop the kit engine in with some details that can only be seen through the cowl opening???
...OR even go a step further and model the bird in a maintenance state with the engine removed...would add some research and work to the engine firewall but there is no way I'd cut that engine down to make it fit. Was it advertised to fit that kit?
:GM:
I like Manny's ideas, too. Seeing that engine as such a build, it can certainly stand on its own. Maintenance would be a great way to display it in all its glory - kit engine could have some battle damage, etc.
But...as said, It is your build and will be outstanding with any choice.
wing_nut
Senior Member
Post by wing_nut »
Thanks for all the comments and ideas guys. Problem is I am as stubborn a a mule and once I get an idea in my head it's a fight to ge me to change my mind. Ask my wife :roll: This is going to be hammered in the if need be :tongue: I don't think it's going to take much to get it to fit.
i do like the museum vignette and now that I know all the mistakes I made doing this one, I'll give it another go. I'll get another one the next time I have a need to place an order. Need? Yeah, like I need any of this. It's all WANT!
wing_nut
Senior Member
Post by wing_nut »
Started working on the exhausts by drilling them out so the pipes walls were scaled to 3/8" thick. No putty needed and just a few wipes with a sanding stick was all that was needed for the fuselage.
You should rename the thread:
"The Corsair, her engine and a mule" :grin:
Good you don't let your self irritate by such a negligibility. This is an epic build!
wing_nut
Senior Member
Post by wing_nut »
Jim, Mostrich... thanks guys.
wing_nut wrote:.... I know all the mistakes I made doing this one,
Mistakes!?!? Where? It's looks brilliant to me.
ajcmac
Senior Member
Post by ajcmac »
Better and better.
Regards
ajcmac
