Eduard BF 110G-2 1/48
scorpiomikey
Post by scorpiomikey »
This is a tentative start to a new build for me. The turkish phantom was starting to do my head in, so im starting the 110.
Ive started in the same place as Owl did with hers, removing stuff i dont need from the trees. Theres almost a whole nother kit there by itself.
Box art.
Link to the page to check the instruction manual.
http://www.eduard.com/store/Eduard/Bf-1 ... hparam=110
Dont know how im going to go, but well see how i get on.
scorpiomikey
Re: Eduard BF 110G-2 1/48
Yeah, i got 2, and i traded one with Owl for a couple of other kits.
I watched Owls build with great interest to spot any issues, not too many in the grand scheme, still disappointing considering its eduard though.
scorpiomikey
Sounds like, as long as im careful i should be ok. I sort of know what to expect now.
Good choice, scorpiomikey!
Eduard revised the kit after release of the C and D versions. Fit of the engine nacelles should be better now.
Have my C-4 in the painting stage atm. Will follow your build and try to give advice when needed.
You'll definitely have fun with it!
nathant
Post by nathant »
The two spots puttied in the underside shot in Jimmy's pic are natural panel lines for the flaps, and are supposed to be there. Someone correct me if I'm wrong though. Doesn't mean there should be gaps, but still leave a natural seam line. These are older releases by Eduard, before they concentrated on better fitting kits.
nathant
Post by nathant »
Gotcha. Did you finish that kit? I too have an Eduard 110D in progress, but sort of shelved right now while I build jets.
