1/32 Revell Bf109G-10 Hartmann
As the work on Black One winds down, I'll be starting on my next project. Another Luftwaffe subject but not a Dora! This is Erich Hartmann's last fighter. Erich Hartmann, nicknamed "Bubi" by his fighting comrades and "The Black Devil" by his Soviet foes, was Germany's highest scoring ace of WW2 and ended the war with 352 kills. He flew different variants of the Bf109 along the Eastern Front, the last probably being this Bf109G-10, Erla-built machine represented beautifully in the profile by Anders Hjortsberg.
There are two known photographs of this machine. Like Dortenmann's Black 1, photos of Hartmann's Double Chevron are limited to the port fuselage side.
Here are the main components of the build.
On the Ready Line:
Revell 1/32 Bf 109G-10 Erla kit
Revell 1/32 Bf 109G-6 kit
Aires Bf 109G-10 Cockpit set for Revell kit
A.M.U.R. Reaver Bf 109G-10 Erla Correction Set
A.M.U.R. Reaver Bf 109G/K Spinner and Prop Blades
Barracuda Studios Bf 109G-10 Intake and Exhausts
Montex Maxi Mask for Bf 109G-10 Revell kit
On Standby:
Alleycat Models Small Wheel Well Bulge Covers for Revell kit
Henri Daehne Bf 109G-10/K VDM Prop kit
Revell's G-10 boxart depicts Hartmann's Double Chevron, which was documented to have the small wheel bulges on the upper wings. Strangely enough, the Revell G-10 kit does not provide those small wheel bulges. The Revell G-6 kit was purchased as a best-fitting source for the small wing bulges. I know, I know... why purchase an entire kit just to use TWO parts??? Remember, I have an extra set of small wheel bulges from Alleycat, as well as the G-10 large wheel bulges so G-6 kit is definitely buildable. One of the subjects I was considering as a sidebuild would be Hartmann's winter G-14 (or G-6)...
Artwork by Claes Sundin
Re: 1/32 Revell Bf109G-10 Hartmann
Subscribed! So excited!
Crack the seals on those Russian resin goodies! Let’s have a Tupperware party!!!
Let's start the Tupperware party then!
I normally start off my builds with a sprue tour. I've already built this kit once before so I think I'll skip it. If anyone is interested, you can PM me and I can send you a link to that build. We'll skip straight to the aftermarket goodies that I have lined up for this build.
The one that I am most excited (and nervous) about is the A.M.U.R. Reaver G-10 Correction Set and 109G/K Spinner and Prop assembly. I believe they are a Russian company and I purchased these from a Russian vendor on Ebay.
The G-10 Correction Set is essentially a engine cowling replacement for the Revell G-10 kit. It is comprised of four pieces cast in smooth creamy resin. In addition to the one-piece cowling, you get the gun breech cover that connects the engine cowling to the front windscreen area, a supercharger intake and the grilles for the oil cooler intake.
I don't know enough to make any claims on the accuracy of this upgrade but I can tell you that it makes a noticeable difference in the lines of the G-10 cowling, especially in width. Looking at the comparison pics on the AMUR Reaver website, you can see the fatter, more stout cross section of the Reaver cowling (on the right) versus the Revell cowling.
Accurate or not, I happen to like the chunkier, more... pugnacious stance of the this cowling. The resin seems to be a quality casting with no apparent bubbles and crisp panel lines. The small air scoops are hollow... a nice touch!
I won't be able to show you a direct comparison between the complete cowlings since the Reaver cowling will require some major fuselage surgery. That's the nervous part for me. I haven't made a larger exterior resin replacement and I'm crossing my fingers that it goes smoothly. I also have a Alleycat Models replacement cowling. It didn't fit well on my last G-10 build so I am just presenting it for comparison purposes. Designed as a drop-in replacement to the Revell cowling, I think the biggest difference is the space between the gun troughs.
The Reaver 109G/K prop set was purchased to ensure that the spinner is a perfect match for the cowling.
The spinner and backplate is cast as a single piece, which is a big improvement over the 2-piece Revell spinner, which puts a very awkward seam in the middle of the spinner.
It looks pretty good. I also have a Henri Daehne 109G/K spinner and prop but I'll be saving that for a future K-4 build methinks.
Rounding out this update is the Barracuda Studios Exhaust and Intake set. I picked this up primarily to replace the kit exhaust, which do not have hollow ends and due to their cross-sectional shape and stacked orientation, would be difficult to hollow out manually.
This set also includes a supercharger intake and some small air scoops that will both go unused since the Reaver set takes care of those already.
The aftermarket tour to be continued...
So excited I can barely think, that is some beautiful resin. I wanted to see the non-manufacturer shots. Nice and crisp! I'm excited for you as well as looking forward to learning a lot. I have the late series G-6 by Eduard cooling its heels in a box right now. Methinks I will be able to do the sanded to primer G-6 flown by Kurt Gabler. So, yes, I am looking forward to watching you build this puppy. Now where 's the rest of the resin...
:clockwatch:
No rush, just curious about the cockpit and the Daehne propeller (did I spell his name right?). Very curious. And excited.
kahunaminor
Post by kahunaminor »
That is some nice resin John. I am looking forward to seeing the results.
Regards,
Kent in Oz
Already getting excited for this build!!
Thank you and thank you and thank you! This pre-build inspection always pumps me up too. That's when my mind really starts to work about possible problem areas and fixes, application of new techniques and visions of how things will turn out.
Let's move on to the Aires resin cockpit. I really like the detail that Aires puts into their resin products. These are are not drop-in replacements and fitting an Aires cockpit into a model can be a challenge. This set is a typical Aires set comprised primarily of grey resin parts and augmented by some photoetch. Two sets of breeches are provided for the different types of center-firing cannon.
The centerpiece of the set is the one piece cockpit floor. Warning bells started ringing in my head as soon as I saw this piece. The casting block is HUGE and will be a challenge to cut this away and leave the thin walls of the cockpit floor and bulkhead intact. I normally would have the option of leaving the majority of the casting block in place since it would be unseen but Revell incorporates spars for the wing into the bottom of the cockpit floor. I'm going to look at this area much closer in the near future.
The sidewalls have some nice detail. Keep in mind that there are additional parts that are added to the Revell sidewalls so they aren't as sparse as they appear.
The kit instrument panel is pretty darn good in my opinion. I think it would look very good with punched instrument dials.
The Aires panel is a multi-media affair with a main panel made of resin, several layers of PE for the instrument bezels and a printed acetate sheet for the instrument dials. The Revell panel is good but I think the Aires panel will be a little better.
Here are the different wing choices that I have. From right to left: Revell G-10 with the large bulges, Alley Cat Models G-10 with the small bulges and Revell G-6 with the small bulges.
Hartmann's G-10 was documented to have the small wing bulges so I am planning to use the Revell G-6 wings. In my previous G-10 build, I found that the Alley Cat wings were on the small side. I used a caliper to verify this.
Laying the Alley Cat wing over the G-6 wing, you can see the difference in size. It would fairly simple to cut and fit a shim to address this size difference so the Alley Cat wing may be put into service on a future build. For this build, I think the Revell G-6 wings will be a good plug-n-play replacement.
Nice! Check out:
http://www.airspacemag.com/panoramas/me ... 180947945/
It will be a challenge carving away the blocks surrounding the Aires resin, but you will do it! I used your advice when I carved up the Aires wheel wells—basically, cut close but not too close at first, then make closer cuts. I use the straight edge Zona blade as a planing tool to remove additional layers of material.
Good call on picking up the additional kit—I was wondering if the Alley Cat’s “Bump” size was smaller as well or if it is the same as the G-6?
Yes, I remember twirling around that panoramic view when building my G-10. Is it just me or are the navigation controls on the pano view the opposite of convention?
I'm not going to be using the Henri Daehne prop but do you want to see a comparison between the HD and Reaver props?
Yes. Absolutely. I want to see the blades. Blades are where the sculpting seems most changeable as a variable for fidelity. I think I may have finally found some good blades for the 1:48 Dora, so since I am unable to use Mr Daehne’s work due to scale, I am most curious!
