Polikarpov I-15 red army Icm 1/72
BsYamato
Post by BsYamato »
Here another 99,9% finished plane i'm working on, the original wip was ... you know about :geek:
Actually just few steps to finish, here a little resume, basically few mods was operated, almost OOB build
Box'n'sprues
... a sprue .. LOL :) up and down
finely detailed as most of ICM kits but the construction is another matter :!:
Cockpit steps, out of belts oob, some junction modificatio was needed to fit all pieces
ready cockpit
The engine, lately i needed to detach rear exhausts part to correct...
glued the fuselage and bottom wing
here with other two russian :) ..theres is another, the Su-2 from ICM but actually freezed
upper wing
metal reinforcers for gears, the kit includes no pins :|
on the tail surfaces too
Rigging with stretched sprue not too tiny in this case
paint it black
and silver mixing, about three thinned layers
decals on after glossy layer, this time fortunately Icm decals was good :)
corrected engine, the problem was the alignment with guns barrels
also a cut on the engine basement was needed to allow a major rotation of the engine in the place, even for guns alignment
first
and after
glued the guns , maded by copper tiny tubes that replaced original rods and the correct alignment
the engine with front cover.. even here some cutting to allow a proper fitting :cry:
and actual situation, all pieces glued, just some retouch needed :)
Forget to write about the rigging.. the correct tension of stretched sprues was obtained with a sprue fired with a lighter, swithced off and carefully put under the wires withouth touch it and just see the wires under tension :)
At the next!
Re: Polikarpov I-15 red army Icm 1/72
Awesome work BsYamato!!
VanceCrozier
Post by VanceCrozier »
Love it Bsyamato. These Polikarpovs are interesting little machines. The fuselage star, I've never seen one like that??
BsYamato
Post by BsYamato »
Thanx friends :)
The star in the fuselage are probably an herald of the particular group for moskow defence.
After few retouches i realized that the polikarpov is finished.. soon final pictures
BsYamato
Post by BsYamato »
Finished :)
Other pictures will post in a single post for latest three finished planes in the proper section :)
Nice job, BSY! Love the model and really like the backdrop. Quite envious of that.
BsYamato
Post by BsYamato »
thank yuo Lyle :)
