Re: Tamiya 1/35 M43E8 "Easy Eight" Sherman
Calling this one done for several reasons. I've not broken anything off yet handling it. I had a gas can handle fly away and found it on the floor, I added the two gas caps to t he cans w/o losing them and a couple of other things. Pressing my luck here.
I'm pretty happy with things as they are. Still processing Carlos' and Shep's weathering tips, so not a lot done there. Went all in on the stowage! Two pieces.....woo hoo!
The tank looks good, Lyle! :shoutout: You're on your way now. :grin: One suggestion, if you will, maybe give it a coat of flat clear now. :hmm:
Yeah, that remains. I thought what I sprayed was flat.. duh. Thank you for the kind words.
You're welcome, of course, my friend! :bow: Regarding that flat; did you spray it through your Gaahleri GHAD68? :hmm: If so, that may be the problem. I've discovered that my flat always looks glossy when using my GHAD68 for that. Something about that smaller needle that renders the flat more glossy. Try the flat clear through a different AB, if possible. I switch over to my old Paasche H for clears now. :grin:
Lyle, this is an amazing job on that tank! You have really nailed that one so well! Way to go Lyle, this has got to be one of your best yet!
Great work Lyle! :shoutout: :shoutout:
Gary Brantley wrote: ↑Fri Sep 12, 2025 9:00 am The tank looks good, Lyle! :shoutout: You're on your way now. :grin: One suggestion, if you will, maybe give it a coat of flat clear now. :hmm:
Its been in the rain..... :whistle: :giggles: :giggles: :giggles:
Looks good, Lyle. Well done! :shoutout: :shoutout: :shoutout: :shoutout: :shoutout:
Thanks, guys. It was a fun build. I did respray with a mare finish.
Great looking Sherman Lyle! :shoutout: :shoutout: :shoutout:
Thanks, Chris.
