Thank Bruce. It was simply filling the panel lines with Mr Surfacer 500, then wet sanding them smooth with progressively finer sanding ticks from 180 grit to 1000 grit. It took a bit longer to sand than anticipated, but turned out as envisioned.speedgraflex wrote: ↑Tue Apr 15, 2025 1:24 pm Bravo! How did you neaten the filled areas? Those look spot on!
And here is todays progress report -
I did the detail painting in the cockpit and engine, then installed the engine
I still need to add a seat harness… once that is done, I’ll install the cockpit and get the fuselage closed up. I also airbrushed on the aluminum for the bare metal areas of the wing using AK Real Color Aluminum
Tomorrow I’ll get those areas masked off, then paint the sealed lacquered areas of the wing using Tamiya LP Gloss Aluminum
