Working on paper! Bristol board smooth plate illustration paper 260g weight. The paper is made in France when I can afford it. Rives BFK watercolor Bristol. Right now I am using Canson paper which is good, too. Markers are usually Sharpie Ultra Fine and Fine, washes are Sakura “Koi” brush pens.
Thanks Bruce, nice stuff! And I hoped you would answer "on paper"! And you did!
:popcorn:
Kemst þó hægt fari. Slowly, steadily... or in this case with a little wavering line... nice part is it is possible to erase and start over if a section looks too weak.
Your drawings looks a lot better than mine would. I'd probably draw a friggin stick aircraft. :giggles:
In any case this is gonna be epic when you pull all of this off. :shoutout:
mustang1989 wrote:Your drawings looks a lot better than mine would. I'd probably draw a friggin stick aircraft. :giggles:
Haha! Somehow I doubt it. I bet you draw pretty darn well! I had to take this “back to square one,” but at least by smoothing the fuselage side down again and adding Milliput, the horizontal seal is tight, and strong!
Filed as “Research.” Subject: “Big Badass Aircraft.”
What a great picture!
speedgraflex wrote:Filed as “Research.” Subject: “Big Badass Aircraft.”
:wub: :wub: :wub:
Return to “Jet GB by Portman”
