Guillows 1/24 DHC-2 Beaver
Re: Guillows 1/24 DHC-2 Beaver
Now she's starting to look like an aeroplane!! Nice job!!
Thank you! Have you bought one yet?
Nope. Haven’t even looked around for one yet.
here you go....I cut the wing struts loose with and was able to get them in a much better position. Think that will be good enough. Float plan is below!speedgraflex wrote:I did a quick internet peek to see if this was a known issue (dihedral) with the kit and it is. Usually what happens to modelers is one wing is higher than the other which Is not the case here. My instinct based on watching your prior builds is to advise you not to monkey around with this on the airframe but do a test with a good CA debonder on scraps of balsa to see if it is possible to release the areas affecting dihedral. If the debonder releases the CA hold easily you may have a solution. Still I advise caution here. Show the parts you have to carve for the float tips. I am curious to see those. Did you try Tower Hobbies for spare parts? Thanks in advance.
LyleW wrote:Okay, it isn't plastic, but it has plastic pieces/parts. Over the decades, and the last one was while I was in grad school....I've tried many times to build these things. Always struggled. Could not get the formers straight, stringers did not line up, could not get the plastic pieces cut out and cleaned up to install....you name it. Oh, I would also manage to break a number of the formers and spend an inordinate amount of time regluing things.
Good to know nothing has changed. I am glad I got this to "practice" with before taking on the DC-3. There is a love / hate relationship with these kits. Can't explain it. Anyway, here is where we are.
In that last picture, over half of the formers have had to be repaired or reattached. Ham-handedness and balsa do not mix well. On the starboard side, I may use the side keel as a "holder" to place the formers.
On a side note, if you have read this far, I bought a bottle of BSI CA glue from Guillows. I ordered the float pieces and had to add something to meet their minimum. Seems to be somewhat better than the Hobby Lobby stuff. My imagination?
Keep posting this Lyle! I love me some balsa builds! What is funny is I just got done watching a bush plane video about the different variations of Beavers in action. Great work Lyle!
Messerschmitt 109 Addict
Wouh Lyle, really interesting!
Kevin, thanks! All that I have left is to finish up the floats (struts and nose piece) and cut/apply the clear “windows”. Hope to use the Silhouette cutter for that.
Kari, thank you so much! You should do one...
Looking good Lyle!
Stuart, thank you! Sort of stuck right now. Just can’t make it do what I want. Need a bjigger hammer, I guess.
