1/72 Italeri/Zvesda Kamov Ka-29 Helix
Re: 1/72 Italeri/Zvesda Kamov Ka-29 Helix
Very nice!!! :shoutout:
Paint work is indeed very nice & realistic
I have washed and flat coated the Kamov. Unfortunatly painted leaked under the windows masking and I damaged the windows during the removing. So I need to restore the windows maybe by polishing it.
All the small pieces are on, it still needs some detail painting like landinglights.
BsYamato
Post by BsYamato »
Good work Borg, a simply toothpick could be good to remove dirt on clear parts :)
I must finish mine :sad:
BsYamato wrote:Good work Borg, a simply toothpick could be good to remove dirt on clear parts :)
It is not dirt, I used laquer based primer so it is etched in the plastic. :scream:
So polishing it is the only option. That or make a cover...
Most impressive! I have one of these too. I certainly need to get started on nit someday soon. It won't be this good, but I have something to aspire to now. Way to go!
Nice! I had one built back in my youth years and did it in white.
You ended up with a nice well used look there! :shoutout:
Paul
Post by Paul »
That is a kick @$$ build. I like it a lot
BsYamato
Post by BsYamato »
I can advice you about my way to replace single windows as i did on the junkers (i ruined some with tamiya green cap) , drill the ruined windows and replace with acetate parts :hmm:
It's hard to accomplish but the result is good
